Enroute failure to process G-code
11/22/26
BH Davis  Member
If you are getting the following failure notice in Enroute when you got to generate G-code it is being caused by the KB5132061 Windows 11 security update.
"Output Failed: Transmit Connect"
Scanvec-Amiable has developed a fix for the problem that you can download at:
https://support.thinksai.com/hc/en-us/articles/55600658783892-EnRoute-Output-Not-Working-After-Windows-Security-Update
It applies to all versions of Enroute.
    • Country Saw and Knife
