Commercial Kiln Drying
Vacuumkiln schedule
8/24/23
Michel Member
I’m trying to determine the best drying schedule for 3”x3”x32”swietenia microphylla @56% mc using a Idry vacuum kiln
4/24/24       #2: Vacuumkiln schedule ...
Kelly Member
Website: https://virmer.com/
Drying 3"x3"x32" swietenia microphylla to 56% MC in an iDry vacuum kiln requires a precise schedule. Consider a gradual reduction in temperature and pressure to prevent checking or warping. Experimentation and monitoring moisture levels closely during the process are key.
7/7/25       #3: Vacuumkiln schedule ...
Wally Robinett Member
I’ve run Swietenia macrophylla at similar dimensions in an iDry. Start at 110°F, gradually ramping up to 130°F over a few days while holding pressure around 25 Hg. Uniform stack spacing and close moisture monitoring are key—this species checks easily. I also add a cooling phase before final equalization. Curious how others handle thicker blocks over 2.5".
