Commercial Kiln Drying
What Stickers to Use without Sticker Stating
11/23/26
Mike R Member
I have about 15, 1''x10''x10' S4S kiln-dried cherry and red oak sitting in my shop and it has gained moisture content of about 12% to 14%. I want to move it from the cold part of my shop into the climate-controlled area, but I don't know what species of stickers I can use without getting sticker staining.
I have plenty of Maple veneer core that I can cut up into 1-inch-wide sections. Is it okay to use Maple veneer core for stickers?
If not, I can always purchase veneer core in any species you might recommend for the proper stickers. Thank you!
11/23/26       #2: What Stickers to Use without Sticke ...
brennan77 Member
Sticker stain is mostly a moisture-plus-chemistry problem, so the main protection is keeping the stickers and the boards from sitting damp together. Maple veneer core is a reasonable choice if it is dry and clean: maple is light-colored and low in tannin, which is why it is commonly used. Avoid oak, and any sticker that is dark or feels wet, because tannins and iron can react at the contact line on cherry and oak. Veneer core can have glue lines and voids, so check that the pieces are uniform in thickness, flat, and not soft, or the boards may print or sag between them. Since the stock is already around 12 to 14 percent, keep the stickers dry, line them up vertically through the stack and about 12 to 16 inches apart with one directly over each end, and let the stack acclimate in the controlled area with air moving past the faces rather than covering it tightly.
11/24/26       #3: What Stickers to Use without Sticke ...
Mike R Member
Thank you, Brennan
I will use the maple veneer core without any glue lines.
