Dust Collection
Subject: Re: Woodmaster Dust Collector DB500 Setup with 8 inch main and 6 inch drops
3/3/15
pran Member
I am trying to set up my duct work for dust collection using Woodmaster DB500 dust collector. This is equipped with a 5HP motor and has air suction capacity of 4,944 CFM and a 6 inch inlet.
I wanted to get your opinion on setting up 8 inch main with 6 inch down drops to machines with reducers that could go to 5 inch or 4 inch, based on machine dust port. Would this work with 8 inch main and 6 inch drops, while the equipment having only a 6 inch inlet?
Link
3/10/15       #2: Woodmaster Dust Collector DB500 Set ...
Ken
The quick answer.... No. First 4944 cfm doesn't exist on a 5hp blower with a 6" inlet. I notice the mfg. doesn't include a fan curve. This is a chart which shows the cfm at a given SP (static pressure), this is the restriction on the blower with duct work and filter. A blower with a 6" inlet would be lucky to move 1200 cfm in the best of conditions. First change the inlet cover to a 8" inlet, then figure 1200-1500 cfm at the inlet. There are a few books on dust collection that explain cfm, sp, main fps vs. drop fps and calculating duct size. Air Handling's web site has a great "Design a Dust Collection System" link that explain this very well. You'll see you design a system from the tools to the collector, i.e. what is the CFM requirements of all the tools that may be used at the same time. You then calculate the duct size and blower size from that.
