Dust Collection
Subject: Re: shop made collection system--could this work?
5/7/15
christian
Hey guys, we cant afford a industrial collection system and dont want to go into debt for one. We have about 10 single bag dust collectors in the shop and i thought up an idea of elimanating the bags on each dust collector and creating one centralized unit using what we have and purchasing the hoses/duct pipes.
Each machine will have just the dust collector motor attached that will blow up into a single pipe. The single pipe will then lead into a large collection bin with a filter bag. This collection bin will also have a dust collector motor to pull from the pipe (to guide dust). Please see the drawing in the picture and provide your input.
Thanks!
dust_collection_system.pdf
5/7/15       #2: shop made collection system--could ...
Dust collection is something that pays for itself if you do it right compared to not. I can't see the performance of many small collectors scaling to the performance of a proper sized machine for your requirements. If dust collection is not working correctly or efficiently work suffers, safety and health suffers, more labor in cleanup and clogs and troubleshooting. The upfront cost spread out to the life of the collector compared to the constant additional labor a inadequate system requires makes a properly designed system the cheaper option in the long run. Haven't looked but I'm guessing there is plenty on the used market, and all the small collectors probably have some value as well.
5/7/15       #3: shop made collection system--could ...
Gary
Mike is right. With that many small collectors you are already paying for a larger unit in extra labor messing with the small ones. Good equipment doesn't cost money, it makes money.
5/7/15       #4: shop made collection system--could ...
Since we know nothing about pipe size, distance, size of blowers, or really any details at all. I vote no on it working. Pretty sure it wouldn't work if you did give all the details. Planer shavings and shaper cutters put out chips so big, they wouldn't want to be shoved through any pipe, let alone 90 degree elbows and a bunch of pipe.
5/8/15       #5: shop made collection system--could ...
Mark Vierno
Wouldn't planer/shaper shavings be broken up once they hit the first impeller?
Mark
5/11/15       #6: shop made collection system--could ...
I also do not see this working as hoped. You are already paying for a dust collector, but you don,t have it. add up your time screwing around with shavings and dust and multiply by your shop rate, for a year. I will bet lunch that the payback would be in less than two years.
Contact Oneida, provide them with a scale layout of your shop with the CFM requirements of each machine, and they will provide you with one heck of a lot of info. Great people to deal with, when you decide it is the best way to get what you need.
