Dust Collection
Subject: Re: woodshop wring class II??
6/21/17
Bob
I just purchased a new building today. Old mill building in great shape.
Had go ahead from fire marshal on first meeting (before close) now on 2nd( after close) he says we must go to construction standards department.
Now they want engineering drawings to install wiring and they believe it is class II so it will be more expensive yet.
Is wood shop considered Class II?
Does that preclude us from using metal clad wiring. (we plan on reusing this from our old shop.)
They are also not aware of the 5000 cfm rule for in-house dust handlers. Anyone know of a link to this statute? In NC.
6/21/17       #2: woodshop wring class II?? ...
cabinetmaker
CFM of dust collector is what the marshall or planner sees on the stamped plate of the collector
Check for egress for the closest door for interior installation Some marshalls, and insurance inspectors have told me they have seen collectors right up against the only exit.
Not sure on your class, but I am sure the planning dept is going to want to see liq tight or emt feeding the machines, outlet, etc
In my many inspections, the fire marshals, and insurance inspectors usually comment about excellent housekeeping, non- existence of clutter and of course up to date extinguisher tags
6/22/17       #3: woodshop wring class II?? ...
Bob
I found the rules on the 5000 cfm in the fire code. More concerned with the wiring.
We were hoping to use the couple thousand dollars' worth of metal clad cable from our old shop.
Anyone else had to use liquid tight conduit in there shop?
6/22/17       #4: woodshop wring class II?? ...
EMT is easier to use than you think. Sometimes following code is in your best interest. Here an electrician has to pull a permit and the inspection follows code.
There is a app for your phone called ibend pipe. It's awesome.
Good luck.
6/22/17       #5: woodshop wring class II?? ...
Bob
Got to talk with an electrical engineer today.
He will be drawing up plans.
We will be able to use the MC cable. :-)
We just need to run it in some oversized conduit up to 7.5' off the floor.
I have no problems with doing it according to code. I definitely want to! I just don't want to overspend. I was surprised to hear this inspector talking about class II. Never came up before and we moved out of the bigger city to a smaller town. Was expecting less red tape not more.
They are more friendly, maybe just less experienced with this type of business.
We finally found a permanent home after moving 4 times in the last 9 years.
I am tired of this stuff.
Steady 50% growth for the last 5 years and on track for 100% this year.
We have more space here than we will ever need and we own it.
We want this setup to be right, safe and efficient, in that order.
Thanks for the input guys!
6/23/17       #6: woodshop wring class II?? ...
If you really want to set it up right..... you want to run buss duct or buss bar through the shop. The net effect is running the fuse panel down the length of the shop. You can then drop power from there to the higher voltage machines. This saves the labor of running conduit (and wire) all the way back to the main panel every time.
It costs more in the beginning and saves money over time. You will also be less reluctant to move things because it cost less. Its one of those things that when you make the investment it is hard but over time you realize it is the right decision.
You can buy used buss duct, make a deal with the electrician that you can physically hang the duct. He can bring wire/power to it and do the drops.
You want to buy used Buss duct. Around here Bull Dog is the most widely available so you can find it used all over the place. When considering the cost keep in mind you need:
Duct, typically comes in 10 foot sections
End cap for the end of the run
Starting cap to connect wires to
Drop boxes of the correct amperage for each drop
Drop cord or conduit to each machine.
If this is your last move it is worth considering.
Good Luck!
6/29/17       #7: woodshop wring class II?? ...
I wish I had but in buss duct in the first place. But at that time my shop was much smaller than it is now. It ultimately saves you $ but even used it isn't cheap.
