Dust Collection
Subject: Re: moulder chip recirculation
1/17/20
MaineGuy Member
Hello,
I am posting this here to inquire as to if any other experienced moulder technicians can confirm what I believe to be the cause of an issue I am having. I set up and operate a Kentwood M609s. I like the machine. I like the work we do. Having two top spindles is a vast improvement to the single top spindle on our previous machine.
The issue I am having is that on many of my larger profiles I am yielding a surface finish that looks fuzzy as though it had been sanded. I figure it is chip re-circulation causing this. The profiles in question are usually profiles that remove a bunch of material on one side, such as with a casing that measures 1.5" x 5" overall, but steps down to about 7/16" at the jamb edge of the casing.
I have seen this when my dust collection spindle hood clogs while running S4S. The finish is horrible but as soon as the clog is cleared the same tooling yields the desired results.
In your opinion, am I barking up the right tree?
Thanks!
1/18/20       #2: moulder chip recirculation ...
Are you referring to what we call 'chipbeat' - where chips ride around the head and get pressed between the wood and the knives, leaving a slight imprint?
It is a difficult culprit to track down. Basically it is dust collection, but we found humidity, feed speeds, heartwood vs sapwood, and even MC of the lumber, as well as species all made a difference. We tried adding supplemental air to increase and/or change air currents. We killed a chicken in the light of a full moon. That does not mean we solved the problem every time. It is a tough one. No solution here, my friend.
1/20/20       #3: moulder chip recirculation ...
Nathan Member
I haven set up/run a moulder in a number of years, however I have been a setup guy/ opperator in the past. We had the same problem on some of our profiles as well. Our tech told us we needed to increase the terbulance inside the collection hood. Depending on the amount of, what he called, "cat claw" we did one of two things. If there was a small amount we removed the door on the hood to allow more air to flow around the cutting head. If there was a larger amount the first strategy didnt solve we made a jig to hold an air tip to blow directly at the cutting line to blow the chips off the tip of the knife. If you do remove the door on the hood make sure there is a secondary saftey of some sort, we ran a weinig that had a large front door that had to be closed to opperate.
    • Sandman Products
    • American Fabric Filter Co.
    • RT Machine Co.
    • Denray Machine
    • Air Handling Systems
    • GreCon
