Dust Collection
Subject: Re: Run capacitor failure causing overheating
11/15/24
Don Member
Website: http://dewoodworking.net
Just an fyi, I was having trouble with my 3hp Oneida Leeson motor overheating and tripping protection. I checked the run and start capacitors and found the run capacitor had failed. After ordering replacements and installing (I did both given the fact they were getting hot against the motor) all is back to normal.
11/27/24       #2: Run capacitor failure causing overh ...
There is a centrifugal switch inside capacitor start motors than can fail and cause the start circuit to remain after start-up. This can lead to capacitor failure. You can usually hear the switch clicking on wind-down of the motor that indicates that it is working.
    • Denray Machine
    • American Fabric Filter Co.
    • Air Handling Systems
    • GreCon
    • RT Machine Co.
