Dust Collection
Subject: Re: Paint Booth Makeup air with 9,000 CFM exhaust
3/10/25
Joe Member
Hi all,
Opened a new cabinet shop and purchased a spray booth with a 9,000 CFM exhaust fan that's being vented out the side wall. Building inspector is looking for my CFM calculation on the makeup air for the building. The shop is 60'x60' with 20' high ceilings. We built a 14x20 room around the booth with two doors. This is a much bigger shop and booth than our previous, so trying to figure out how much CFM I'll need for the makeup air coming into the building. My HVAC guy thinks a louvered cutout in the wall should be enough, but I'm wondering if I need an intake fan as well. I'm having trouble figuring out the calculations needed.
My plan is to get a louvered fan unit (rated for 9,000 CFM) that turns on when the booth exhaust fan turns on. It will be cut it into the wall up near the ceiling on the opposite corner of the spray booth. The booth/room will have filters cutout into the walls to allow air in.
Do I need the full 9,000 CFM for the makeup air in a building that size?
Thank you for all the help,
Joe
3/13/25       #4: Paint Booth Makeup air with 9,000 C ...
chris
post this in finishing section. probably get more help there.
4/25/26       #5: Paint Booth Makeup air with 9,000 C ...
BH Davis  Member
If you have 9000 cfm going out you need 9000 cfm coming in. Otherwise you'll draw a negative pressure vacuum on the space. I don't see why you would need a fan to push the make up air in. Any opening that allows air into the building will aid in generating the volume of replacement air. Bear in mind though that the smaller the opening the faster the air will be moving as it comes in.
You also need to give consideration to the incoming air temperature and humidity level. If you are in the south with air conditioning, or the north with heating, you need to consider what that incoming air flow will do to your indoor environment.
I agree that posting this on the finishing forum might get you more precise results.
    • Machinery Associates
    • GreCon
    • American Fabric Filter Co.
    • Sandman Products
    • Denray Machine
    • RT Machine Co.
