Mesh Tarp for 40 Yard Dumpster
1/29/13
Hello! We use a 40 yard dumpster to collect wood chips from our machinery which we use to make flooring. The chips are blown into the dumpster, and the finest exit at air leaks around the perimeter. It is dusty. We are wondering if a mesh tarp will help solve this problem. Does anyone have experience with mesh tarps? Or can anyone recommend solutions for the described problem with the dumpster? Thanks in advance!
2/5/13 #2: Mesh Tarp for 40 Yard Dumpster ...
Joe,
I have spoken with several guys that have used burlap.
Curt
2/6/13 #3: Mesh Tarp for 40 Yard Dumpster ...
Return the air from the dumpster back to the inlet of the fan with another length of ductwork creating a closed loop and you will get almost no dust. This way you eliminate pressurizing the dumpster.
2/21/22 #4: Mesh Tarp for 40 Yard Dumpster ...
The Mesh Material is for use in Construction Sites as well as commercial parking lots. Keeping these elements out of the dumpster ensures that the inside stays dry and your site meets EPA standards.
7/14/24 #5: Mesh Tarp for 40 Yard Dumpster ...
Hi, your best option is a poly tarp as it would provide a more airtight seal, reducing dust escape significantly.
poly tarp
