Dust Collection
Shelix cutterheads
8/17/20
Tadhg
Hi all I have all Shelix cutterheads in my shop and time has come replace a full set so I can have another sharpened
There big difference in price between Powermatic and Byrd. As Powermatic are over double so general rule is you get what you pay for. But each head takes 50 pcs Has anyone tried Byrd and are they good quality or do I go with brand I know
8/18/20       #2: Shelix cutterheads ...
You don't have to go through either. They are industry standard inserts.
All carbide is not the same.
Try your sharpener or whomever you buy blades and cutter heads from.
I buy all my inserts through Great Lakes Custom tool. They are probably not the cheapest but I know I will get quality.
If the choice is Byrd or Powermatic I would go Byrd. They have a vested interest in supplying the best insert for their product and probably buy in high volume.
8/18/20       #3: Shelix cutterheads ...
Tadhg
Thanks bill my issue is I need a New set to replace set that is being sharpened as I use both machines most days But I might try your company for price and purchase new set from them also thanks again for advice
T
8/18/20       #4: Shelix cutterheads ...
Dustin orth
I think you are making a mistake in trying to sharpen the square carbide inserts. They are designed to be thrown away once you have dulled all 4 edges. Sharpening them will change the dimensions of the insert in both your cutting circle and how it references in the cutterhead. Just order new cutters and save the headaches. I order my inserts from CGG Schmidt or Global Tooling. I have Byrd tool heads as well as most other brands as well. So I have found you need the inseets to match the head, dont just go off of dimensions. There are subtle differences.
9/29/20       #5: Shelix cutterheads ...
Mark Member
You are aware that Byrd grinds their inserts with a slightly cambered edge which they claim leaves a better quality cut. Most carbide inserts have a square cut.
9/29/20       #6: Shelix cutterheads ...
Other manufactures make inserts with the radius. Heads made for the radius and inserts with the radius are not specific to them.
9/29/20       #7: Shelix cutterheads ...
Tadhg
Hi guys I called my blade sharpener supplier and they do not sharpen Shelix cutter heads They said same as Dustin throw them away and buy new set i opened both machines and think I have one side left but I going Take bill advice and place call to Great Lakes For pricing if there in ballpark ill get one set for now then later on I’ll replace other I thought of upgrading to Martin Or similar but with COVID and economy at moment it’s not option now ,what I have will do for another while ,to be fair neither has given any trouble since they were bought 6 years ago So no complaints
    • American Fabric Filter Co.
    • Machinery Associates
    • Sandman Products
    • Denray Machine
    • GreCon
    • RT Machine Co.
