Dust Collection
a add on dust collection for mdf dust
10/8/21
Farmer Billy
Is there anything you can add on to outside dust collector to catch finer dust especially mdf dust. The company i work for the dust collector work great inside but on the outside it blow fine dust out. To much fine dust is going out in the air( neighbors is complain about mud in their blacktop driveway) Any ideal would be appreciate. Thank
10/8/21       #2: a add on dust collection for mdf du ...
bill Member
I have a some questions.
Is the air returned to the building?
Is the air filtered before it is exhausted (assuming outside)?
Either you need to fix the filters because one or more is leaking/torn or add filters. The problem is that anything you do in addition to the original design will cause static pressure and reduce the performance of the system.
10/8/21       #3: a add on dust collection for mdf du ...
Farmer Billy
No to both the big wood chip goes in a hopper. But we cut mdf more then anything Else. Thank
10/8/21       #4: a add on dust collection for mdf du ...
Billy - Come in off the farm and get with a professional system.
Call Oneida Air Systems or equal and describe what you want to do.
You will end up with a tight, efficient system that removes most of the MDF dust.
10/26/21       #5: a add on dust collection for mdf du ...
BH Davis  Member
Some business owners are not going to spend a lot of money to upgrade a dust collection system to include return air to the building. If you are in a warm climate and don't air condition the building then it is hard for an owner to justify the cost. That could be the case for your owner.
A less expensive solution may be replace the hopper with an enclosed trailer that can be hauled away to be emptied. There will need to be an air escape window cut into the trailer wall with a filter. This filter will require regular maintenance/replacement but it should help to solve your problem. The larger the filter cutout in the trailer wall the longer between changes. I think I'd want a filter cutout that was at least 24" x 24". Larger would be better.
10/26/21       #6: a add on dust collection for mdf du ...
Bernie's solutions are good also. No matter what fix you use, it needs to airtight or else it will not draw.
And if you exhaust only, with no return air, you might run the risk of your combustion heat source poisoning you. The shavings fan can overcome the gases going up the flue from your furnace, and bring them back into the workspace. This is carbon monoxide, a killer.
If you exhaust shavings, etc to the outside, and have a combustion heat source, you will have problems.
    • Air Handling Systems
    • RT Machine Co.
    • GreCon
    • Denray Machine
    • American Fabric Filter Co.
    • Sandman Products
