Dust Collection
Torit dust collector
9/2/23
Pat m
Where does fan blade need to be located in housing for best operation.? I replaced motor with identical spec motor but it has a stepped shaft, so fan blade is moved closer to motor than before. Performance is way down. Thanks for your help.
9/8/23       #3: Torit dust collector ...
chris
are you sure wiring is correct and motor is spinning right way?
9/8/23       #4: Torit dust collector ...
Pat m
Wiring is the same as before, but also correct., As is direction. But I did change direction just to check, it was worse. FYI it has 7.5 230 volt 3phase motor on it.
I'm actually an electrician, with buddy that owns cabinet shop. I just can't help but think, the fan blade being moved up approx 2in, towards the motor, would have a determental effect on performance. Kinda like not having a shroud on automotive engine fan. Thanks for help
    • Sandman Products
    • RT Machine Co.
    • GreCon
    • Denray Machine
    • American Fabric Filter Co.
