Subject: Re: White conversion varnish on Louver doors
1/24/15
antonio
Website: http://www.positivewoodworks.com
Have any of you guys sprayed pigmented CV on louvered cabinet doors? We have a job coming into the shop that calls for a particular sherwin color. We are thinking of having them mix it in CV instead of acrylic. But im wondering if all of those little corners where the louver meets the stile/rail will pose a problem with puddling etc.? I'm sure the client will appreciate the durability and smooth texture of CV but what will all those corners look like in a few months? all cracked up?
1/25/15       #2: White conversion varnish on Louver ...
Leo G
I did a whole house of louvered shutters. Worked fine. But all the sanding was crazy.
1/25/15       #3: White conversion varnish on Louver ...
Mitch Suber
Website: http://subercustomshutters.com
I sometimes build louvered cabinet doors for local shops that are not set up for building them, and at times we finish them as well. Painting or clear coating them is similar to the way we finish our fixed louver exterior shutters, so with the right technique, puddling in the corners can be avoided. We use the same method with lacquer, oil and acrylic paint.
At first we cut in the inside edges of the stiles, where the louvers fit into the slots. Make a few vertical passes with the paint volume adjusted down. I also cut inside the rails too, and hit the outer edges of the panels at the same time. Stop and allow this to tack, or dry as much as your time window permits. We then make the horizontal passes in a manner so that we go over the danger area fairly quickly. Apply several coats to get the correct build.You might want to try this on a sample panel first, but stay with multiple light coats. If you get impatient and make just one pass that is too heavy, your done for.
Actually our panels allow the louvers to free float, same as a fixed panel, so there will eventually be a fine line where the paint breaks anyway.
1/28/15       #4: White conversion varnish on Louver ...
rick morehou Member
in the 70s as an apprentice I have sanded those things until my fingers blead as I realize now that the Spray Men then did not know how to Spray( Sand sealer Finish..). There are ways to tell if you are a competent Spray Man, if you have to ask you are not one. Anyway , I love CV, I never have the problem you are describing , Perhaps simplifying your pattern will help. One Pass
Hope it helps. I look forward to Mistakes now ...thanks Rick M
