Subject: Re: striping or shadowing streaks in finish
3/8/15
christopher silsbee
I am using a ca technologies system for finishing. When I finish dark colored stains or paints especially on big panels. I have streaks , dark and light streaks. Fluid preassure is 30psi and air is set at 15 psi. Fan pattern is good no tails, and even fluid across pattern. I am at my wits end and would appreciate any advice. Tried everything I can think of. The tip is a 411.
3/8/15       #2: striping or shadowing streaks in fi ...
Leo G
Are you box coating. 2 coats, 1 90 degrees to the other.
3/8/15       #3: striping or shadowing streaks in fi ...
Sounds like application technique problems. Too far away, too close, too fast, too slow, not enough overlap, not staying parallel to the surface, not consistent movement.....Any of those sound likely? I may be off base since I have no idea about your experience. Practice techniques on cardboard and see if you can get it better with different technique.
3/9/15       #4: striping or shadowing streaks in fi ...
Joe Member
If you are using the CATech AAA, your settings hint at that, try increasing our air pressure some. it will atomize a little better and spread out the fluid more from the tip.
You can even decrease your fluid pressure a little, but that is harder to adjust.
3/9/15       #5: striping or shadowing streaks in fi ...
Bill Richardson  Member
Website: http://www.awwtx.com
I've had the same problem using a Kremlin. Technique was the issue, I was spraying too close. Try keeping a consistent 8" distance from the surface.
3/9/15       #6: striping or shadowing streaks in fi ...
Rick Mosher  Member
Website: profinisher.blogspot.com/
I don't use that equipment but from what I read on their webpage a 411 tip is an 8" fan which seems kind of small for large panels. They have a 611 tip which has a 12" fan and the same orifice. Maybe that will help as well as the advice above.
3/9/15       #7: striping or shadowing streaks in fi ...
Brian T
I've seen the problem arise in the past but usually in the summer. If it's not your technique then try using a slow drying thinner or adding a small amount of retarder. Keeping a wet edge is key when you have striping issues.
Also what sheen are you having the problem with. Typically we only ever see striping low sheens, 20 or less.
3/9/15       #8: striping or shadowing streaks in fi ...
chris
thank you all very much for the advice. it is greatly appreciated. i will try to improve my technique, fan pattern, and possibly a new tip on my gun. thanks again.
3/9/15       #9: striping or shadowing streaks in fi ...
chris
the conversion varnish is chemcraft 20 sheen
3/11/15       #10: striping or shadowing streaks in fi ...
joe
Chris,
is your inline fluid filter clean free of blockage ? When you refer to striping are you seeing sheen variation ?
3/14/15       #11: striping or shadowing streaks in fi ...
chris
yes it is a sheen difference in the pattern.
3/15/15       #12: striping or shadowing streaks in fi ...
joe
Chris,
I've seen this happen and you need to make sure your screens are free and clear with no restrictions. Is the CV a lower sheen? What can happen is the matting paste in the product can sheer/separate from its solution under the fluid pressure created by your AAA. What is your Rep saying? Have you tried a different method to rule out your spray system?
3/15/15       #13: striping or shadowing streaks in fi ...
chris
the sheen is 20. the rep has no idea what to do. the filter isn't the best. i will get a new one coming.
3/15/15       #14: striping or shadowing streaks in fi ...
joe
For now just remove it and see if you yield better results, Maybe then you can educate your Rep...is the CV Plastiofix or E-Var..
3/16/15       #15: striping or shadowing streaks in fi ...
chris
it is chemcraft 24 and i also use becker acroma.
