Subject: Re: cv over stain with mineral spirits
3/14/15
nicko Member
i have some stain i need to use on a interior trim project. The home owner gave me the stain to use to match the existing trim that he stained five years ago and the stain is a little thick in the can.
i mixed a little mineral spirits in the stain and stirred it and it thinned it out nice and dried nice on my sample board.
will there be any adhesion problems spraying sherwood water white cv over the stain with mineral spirits?
thanks...................nicko
3/15/15       #2: cv over stain with mineral spirits ...
You should be fine if you let the stain dry well and use a vinyl sealer first to be safe.
3/15/15       #3: cv over stain with mineral spirits ...
nicko Member
thanks Mike
the cv i use is self sealing and i use it that way by thinning it with xylene. I still think it will be ok if i let the stain dry good.
but i wanted to see what someone else thought
thanks.................nicko
3/16/15       #4: cv over stain with mineral spirits ...
I use the same stuff...Vinyl is just way more forgiving and not as sensitive to what's underneath it like CV.
