Subject: Re: door finish
door finish
5/10/15
GPWOOD Member
I have a customer with a old painted exterior door that is highly distressed. She would like to repurpose but save the old finish and look as is. My question is what finish could i seal it with to encapsulate the old finish for interior display.
5/11/15       #2: door finish ...
Kevin
sealer
5/13/15       #3: door finish ...
DCS
GPWOOD, What will the door be re-purposed as? If it will be used as an interior door, I do not see the need to do anything to the finish...If it will be turned into a coffee table then a finish will be needed to preserve the existing paint.
I would not recommend using just a sealer. May be too soft.
I would probably go with a simple polyurethane in an appropriate sheen and move on...
I think your biggest issue will be adhesion to the existing finish...Poly urethane will only require a mechanical bond (sanding) to achieve adhesion...Good luck.
