Subject: Re: Refinishing Polyurethane coated exterior doors
6/14/15
Michele K  Member
Website: ferniewoodfinishing.ca
I'm looking for advice on refinishing a suite of exterior wood doors finished with Chemcraft D-Dur polyurethane. They were finished about 7-8 years ago and now need some TLC. Any recommendations? Some of the doors are in great shape, they'll only need a cleanup and refresher coat. Others have some slight cracking and peeling finish at the stile and rail joints. They were stained before they were clear coated, so any spot repairs will have to be blended.
6/16/15       #2: Refinishing Polyurethane coated ext ...
RobertJ
ML Campbell makes a Maintenance Coat for 2K poly.....don't know if it would be applicable in your case.....2K is 2K.
Would probably have to remove the door and take it back to your shop for optimal spray conditions.....tough to spray onsite unless you have a turbine or large compressor
ML Campbell
8/11/15       #3: Refinishing Polyurethane coated ext ...
JT
Milesi also provides an Exterior maintenance coat for some TLC.
