Professional Finishing Forum
Subject: Re: Inside cabinet spray technique
8/1/15
Bill Richardson  Member
Website: http://www.awwtx.com
We bought a Kremlin 10-C18 a while back that has been primarily used on large open areas applying CV. We build a lot of large banquet style tables for a local restaurant. I have a display cabinet that I need to spray, but one area of the cabinet is 10" high x 24" wide x 18" deep. How do you adjust the AAA for such close quarter spraying?
8/2/15       #2: Inside cabinet spray technique ...
CWK
with AAA's you adjust your style of spraying more than adjusting the equipment. Also depends what size tip your using. If using a large tip like a 13, go down one size. This may cause use it hit it with one more pass to get flowout but it's easier than sanding out runs.
8/3/15       #3: Inside cabinet spray technique ...
JeffA
Take the back off.
8/3/15       #4: Inside cabinet spray technique ...
I never spray with the back on. I was referring to the lack of height, not depth.
8/3/15       #5: Inside cabinet spray technique ...
herb johnson
i might drop the tip size or the fluid pressure, when i do flats i have go very fast and when i do interiors i slow the fluild delivery so i don't get any runs or sags,
with the spray being soft i don't take the back off of everything
8/3/15       #6: Inside cabinet spray technique ...
The only items I spray are the ones we build, so I always do the finish work before I install the backs.
I'm still trying to develop a better technique with the AAA on detail work.
8/3/15       #7: Inside cabinet spray technique ...
JeffM
Prefinished UV ply or spray before assembly on stained interiors...
8/4/15       #8: Inside cabinet spray technique ...
Prefinished ply is unacceptable for what we build. Too many issues with spraying prior to assembly.
8/4/15       #9: Inside cabinet spray technique ...
Leo G
If you do this often enough then you might like this. It's a head for an automatic spray system. Put a wand on it and you can get into small spaces.
AXC Airmix® spray gun - Stainless Steel
