Subject: Re: Stain Applicator
Stain Applicator
10/27/15
Im getting more and more calls for single home custom moulding runs. Anyone know of any type of stain applicator that speeds up the job for wipe on (not spraying)? I keep thinking of something like a quart glue bottle with a dauber on the end, something like shoe polish? Im just talking about getting the wet coat on there With some type of applicator where they can walk down a piece of 3" trim to get the stain on. Ragging it off is always fast.
Ive done a bunch of googling but come up empty. Before I went at some sort of shop made attempt I figured Id ask.
10/27/15       #2: Stain Applicator ...
JeffA
How wide is the trim? Are you using waterbased stain or solvent? Have you looked into a paint roller? They make small ones about 3 inches wide. I'm not sure about using solvent stains. Oil based may not be too bad but not sure.
10/27/15       #3: Stain Applicator ...
Widths vary from as narrow as 1 1/2" for nosings and base caps, on up to 6" or so. I realize no solution is going to work well for all but just tossing it out there. Tried various rollers in the past, foam, trim, thick nap, but with a rigid roller if the trim has any profile depth a roller leaves many areas untouched and other completely flooded.
All solvent. Mostly MLC spray and wipe. Most all of our work requires a wiping stain.
I am envisioning some sort of quart bottle with various diameter pom pom type swabs which could be attached to the end of the bottle. Perhaps varying sized orifice discs that are inserted before screwing the cap on depending on viscosity to keep the swab saturated with a squeeze of the bottle.
That'll likely be my attempt if nothing comes up.
10/27/15       #4: Stain Applicator ...
afinisher
Check out Harbor Freight staining pads- 8 for $3.
Stain Sponge
10/27/15       #5: Stain Applicator ...
Paul Snyder  Member
Website: finishing.tips
Why not spray & wipe? It's very fast and easy to control width and flow.
10/27/15       #6: Stain Applicator ...
Robert Member
A Hudson 67215 works great..no over spray
10/31/15       #7: Stain Applicator ...
Rick Mosher  Member
Website: profinisher.blogspot.com/
3M PPS system on a cup gun or a pressure pot system. Use VERY low pressure, just like a hudson sprayer, no overspray, fast and then wipe off. Why not just use an NGR dye stain? Spray it on wet and you're done. No wiping, dries almost instantly.
    • EX-FACTORY
    • Apollo Sprayers Inc.
    • Supergrit Abrasives
