Subject: Re: Finishing Bamboo Rods
10/31/15
Montague Member
Finishing a bamboo rod has always been labor and time intensive. An old salt offered up that white shellac mixed in equal parts with tung oil and rubbed on with a cloth will give a better finish with less work. I have some concerns about waterproof/resistance with this method. What is your opinion please?
10/31/15       #2: Finishing Bamboo Rods ...
Rick Mosher  Member
Website: profinisher.blogspot.com/
If you are building these rods (very time consuming I believe) why would you want to take a short cut on the finish?
11/1/15       #3: Finishing Bamboo Rods ...
Paul Snyder  Member
Website: https://profinisher.blogspot.com/
I would not try that mixture - they are not compatible and neither is very durable or waterproof. A wipe-on varnish would be a much better choice and very easy to apply.
What type of finish are you using now and how do you apply it (what makes it so difficult)?
11/1/15       #4: Finishing Bamboo Rods ...
Nick
A few of my friends make bamboo rods and they use spar varnish; easy to apply and maintain and also very important, fexible.
Their method is to somehow attach it to a very slow rotating drill then applying slightly thin coats with a small ox-hair brush while rotating...they come out perfect
11/1/15       #5: Finishing Bamboo Rods ...
Shellac is really brittle and in my opinion, has a very low tolerance of being exposed to water. I can't imagine the inventor of that finish is a chemical engineer. I prefer to let that up to people that actually are trained in chemistry and work very hard to make good products. I like Nick's suggestion of spar varnish.
    • Apollo Sprayers Inc.
    • EX-FACTORY
    • Supergrit Abrasives
