Subject: Re: Are Sata hvlp guns all that?
11/6/15
Joel
Hi,
So today I used a very expensive gun for the first time. A SATA HVLP top cup one. My boss said it cost $600. I used it to paint with tinted CV. He set the gun up but I gotta tell ya it didn't spray any better than my Devilbiss I got for $20. Are these things worth the money??? Thanks...Joel
11/7/15       #3: Are Sata hvlp guns all that? ...
Sean Jackson Member
If your turbine is good (3 or 4+stages) then a cheap gun will give pretty good results in the right hands. Having control of amount of air at the gun, fluid control and good fan control are staple with a quality gun, with cheap not always having air control. Further to that comfort/reliability and parts follow, but sure, I can shoot a good flow coat on my old cheap gun as I can on my quality one no probs - and that goes all the way up to piano finishes using hvlp. I'm sure there are benefits/differences with AAA and old compressed air regarding delivery but HVLP systems are great in the right hands for my money.
11/7/15       #4: Are Sata hvlp guns all that? ...
afinisher
Remember- the goal of hvlp is not to achieve the finest atomization- rather to reduce the overspray as much as possible in particular where shops are dealing with stringent air quality standards. Sata RP models deliver more material faster and finer atomization than HVLP- while also delivering good material transfer= less overspray.
I don't know Sata as a user- Certain Devilbiss models allow for use as HVLP or HE (high efficiency- same as what Sata calls RP- reduced pressure) by simply changing out the air cap. In the case of the Devilbiss Transtech- there is a big difference in the speed and atomization of the HE aircap compared to the HVLP air cap.
Not sure if the SATA HVLP allows for the same flexibility
11/7/15       #5: Are Sata hvlp guns all that? ...
herb johnson
they are nice guns till you start to buy needles tips and air caps, they do spray well but imho no where near worth the money but they have a loyal following,
good luck
herb j
11/8/15       #6: Are Sata hvlp guns all that? ...
Nick
I agree with Herb...fantastic spray guns but compared to binks, devilbiss, cat, ect...they are overpriced. That said I do own 4 (2 1000k rps, a 2000b rp and a mini) and use them often. The 1000k with a 1.3 is hands down my favorite wb clear coat gun.
11/8/15       #7: Are Sata hvlp guns all that? ...
Bob J Member
Ihave a Sata hvlp gun that I use for non water borne finish's and love it over my other guns. One thing about quality guns over the cheap ones is stainless steel fluid passages, the cheap ones my have (most don't) stainless needles, nozzles and caps but the fluid passages are not and will pit.
11/8/15       #8: Are Sata hvlp guns all that? ...
herb johnson
any good from binks dv whoever has stainless passages which is a good thing
good luck herbjh
