Subject: Re: sanding before Amazing Glaze
12/3/15
Dan
i've always did a very light sand with a worn sponge before the amazing glaze. then sand the amazing glaze then topcoat with Krystal.
have any of you not lightly sanded before the glaze? i'm thinking the sanding of glaze will be good enough. the glaze is on MLC resistant
12/3/15       #2: sanding before Amazing Glaze ...
Paul Snyder  Member
Website: finishing.tips
Dan,
The data sheets for Amazing Glaze and Campbell's catalyzed coatings recommend you sand between coats to ensure proper adhesion. Usually you want to re-coat within 8 hours of sanding.
If you want to skip the sanding step, do some thorough adhesion testing in advance. FYI - Campbell won't warranty the finish if you don't follow the application guidelines (no manufacturer will).
12/4/15       #3: sanding before Amazing Glaze ...
JM
Its better to sand before the glaze. That way you only have to worry about scrubbing the glaze off to control the look.
If you only sand after the glaze, you will have to try to sand smooth and create the glaze effect in one sanding step. I suspect you will end up with less than desirable results this way.
12/6/15       #4: sanding before Amazing Glaze ...
Dan
Thanks guys. Yeah I'll keep sanding prior to the glaze. Not worth it to skip a step.
12/6/15       #5: sanding before Amazing Glaze ...
Dan
12/7/15       #6: sanding before Amazing Glaze ...
joe
I'm under the impression that the sanding of the Resistant prior to applying amazing glaze is not required . As your removing the glaze with your sponge or scotchbrite you are then creating adhesion for your Clear Coat. if sanded prior it may be difficult to remove it and create the look needed.
    • Apollo Sprayers Inc.
    • EX-FACTORY
    • Supergrit Abrasives
