Subject: Re: corner cupboard doors binding
12/30/15
jonmcay
I got a corner cupboard from a customer that was in a barn. I got it stripped , repaired and finished. The problem is that the top doors are binding at the hinges when it is about 2 inches from closing. I have sanded the sides. Put cardboard shims in the hinge slots in case the mortise was too deep and check to see if the hinges were bent. Any ideas to solve this beside putting magnetic catches and telling the customer that the best it will be. Any help would be appreciated.Thanks .
1/2/16       #3: corner cupboard doors binding ...
Paul Snyder  Member
Website: finishing.tips
Jon - post pictures of the hinge showing both sides, how it's attached to the door and cabinet, and a close-up of what it looks like when it's in the (nearly) closed position.
1/9/16       #4: corner cupboard doors binding ...
Jake Member
Jon did you check to see if the doors are rubbing on the shelves? i would bet that the doors are set to deep.
    • EX-FACTORY
    • Apollo Sprayers Inc.
    • Supergrit Abrasives
