Subject: Re: Thuya Burl finishing
2/16/16
Jon Anderson Member
Website: http://www.jonandersonpottery
Thura Burl seems to be a really oily wood , I'm having trouble with polyurethane drying on this wood, any suggestions.
2/16/16       #2: Thuya Burl finishing ...
nick
Just a thought...it might not be the wood. Is it cool and damp where you are? If so, turn up the heat and turn on a box fan. When drying oil-based poly; 70 degrees with a little air movement makes a world of difference when compared to less than 50 degrees and still.
2/16/16       #3: Thuya Burl finishing ...
Jon Anderson Member
Ya .I've had this trouble before with Thuya burl. All the other pieces dried and I did bring the Thuya into the house and it's still wet after 36 hours any Ideas are welcome. I'd put some air on it , a fan or something but it's still to moist it would be covered in dust.
What I'm hoping for is to get the first coat dry somehow and I'll be finishing on the dry Poly after that. Maybe
Beautiful wood just real hard to finish.
2/17/16       #4: Thuya Burl finishing ...
Arthur Grudko
Try Smith's epoxy penetrating sealer as first coat.
2/20/16       #5: Thuya Burl finishing ...
Joel
I've had problems with those exotic burls not drying using poly myself. For me it took about three days but it eventually hardened up completely so yours probably will to. I don't see how a fan blowing on it would cause anymore or less dust in the finish. If you are going to sand and recoat anyway who cares?
