Subject: Re: DOOR FINISH
DOOR FINISH
3/7/16
Chris
Hi. Anyone know how this type of door finish gets done?
Im guessing 2 coats black primer, 1 coat of black topcoat, sand off distressed areas and apply red stain?
3/7/16       #2: DOOR FINISH ...
Snaglpuss
I would put the finish dark over the red and scuff / sand / distress through to the desired level of messedupness.
Is that a word?....
3/7/16       #3: DOOR FINISH ...
PainterDave
red first and then black,
sand through the black
3/8/16       #4: DOOR FINISH ...
JM
I do this thing all the time.
Stain first, seal with clear, primer tinted to colour, sand through, clear.
If you try and stain after the colour coat, it will bleed and discolour around the area a little.
3/8/16       #5: DOOR FINISH ...
Chris
thanks guys :-)
3/8/16       #6: DOOR FINISH ...
Mark V.
Conestoga does it....
Color coat
Sand through
Stain/Glaze
Clear coat
Mark
3/8/16       #7: DOOR FINISH ...
Jim Conklin  Member
Website: http://www.jhconklin.net
When I zoom in on the photo, I don't think it is a rub-thru. Looks like an applied color over the black similar to a dry-brush or cowtail technique when glazing.
build black to desired saturation
light scuff
dab, brush, smear contrast color
clear
3/9/16       #8: DOOR FINISH ...
kevin
that door was definitely red before it was black. you can see the red popping threw in the corners of the raised panel where the black doesnt cover.. . also you can see the red threw the black in several places where it was very lightly burnt threw. Besides the fact that red would not be that vivd if brushed on top of black.
3/9/16       #10: DOOR FINISH ...
nicko
i thing general finishes website shows how to do a finish like that
nicko
3/31/16       #11: DOOR FINISH ...
DCS
This finish appears to be a rub thru finish...The application of hard wax on the edges will help in the rubbing effect after colored finish (black) is applied..
Have done similar finishes many times...
Good luck
