Subject: Re: HelmsmanŽ Spar Urethane
4/20/16
Richard Member
What do you pro's think of this finish for outdoor furniture and wood signs?
4/20/16       #2: HelmsmanŽ Spar Urethane ...
RobertJ
Job security for life. Will fail in less than One year upon direct UV. Alternative:
Awlgrip Alwood MA.
4/20/16       #3: HelmsmanŽ Spar Urethane ...
Leo G
The great thing about it is when it fails it sands off real easy. Garbage.
4/21/16       #4: HelmsmanŽ Spar Urethane ...
Save a few bucks and use the Minwax floor poly instead. Who knows it might have better UV resistance.
Nice touch with the registered symbol?
4/21/16       #5: HelmsmanŽ Spar Urethane ...
nick
I have had good success with it. For example a couple of weeks ago I looked at refinishing (6) 8' fir doors on a retail business I did when new 5 years ago. Direct south exposure at 2,000' elevation on the west coast (that means a lot of sun), awning keeps the rain off them but they get full sun. They should have been refinished a year or two ago but they aren't bad as there is just a little failure at the style/rail joints and at the bottom of the window. Nice even amber color. It is important to note they were sealed with an epoxy sealer and I am sure that is a key factor in the longevity of the finish.
I prefer a penetrating tug oil finish on exterior furniture; maintenance is more frequent but easier.
4/21/16       #6: HelmsmanŽ Spar Urethane ...
Leo G
I have a bench out front. I put the Helmsman on it every year. Had to because it was flaking off. It sanded off very easy. Only took about 20 minutes to strip the bench with an RO sander.
Last year I used a boat urethane, Easypoxy. $110/gallon. So far it's made it through the winter and still looks new.
4/24/16       #7: HelmsmanŽ Spar Urethane ...
Bill Richardson  Member
Website: http://www.awwtx.com
Low end DIY home center crap
4/24/16       #8: HelmsmanŽ Spar Urethane ...
Robert Chickey Member
You want something that will give you five years plus. Then use Chemcraft D Dur. I was a big skeptic but results don't lie. It is a catalyzed product. And obviously has to be sprayed.
