Subject: Re: Finsihing Oak
Finsihing Oak
5/18/16
Joe Member
Hi Guys,
Hey got a question for you all.
When I finish the bases of my clocks,mainly I do the routering of the edges and a sanding of the edges to remove any saw marks and fuzzies from the routering.
Then I actually found that when applying the Sanding sealer ( zinzer ) I was at first brushing, then tried rollering, all of course worked, but was slow and tedious work.
I now actually dip and submerge them in a shallow tray, drop them in , let them sit for like 30 seconds, pull them out, and let dry, Makes a perfect brush mark free sealing coat.
The sealing works great for all the 4 wood types I use. Maple, Walnut, Cherry, and Oak
. A simple sanding, and then one single light gloss coat and it's like a piano! A mirror smooth and glossy finish.
Except for the Oak. The deep ummm "Pores"? still show, I have even tried multiple coats of the sanding sealer, and gloss, but you can still see in the surface those "Pores"
Do you guys just leave it as a part of the natural part and characteristic of the wood, or what do you do to level it off so the final gloss finish ends up without all the pits?
Joe
5/18/16       #2: Finsihing Oak ...
Robert Member
Paste Wood Filler is formulated to fill the pores on woods like Walnut,Oak,Mahogany etc.
You may have to come up with another way to finish them though as dipping a Paste Wood Filler in the Lacquer may soften up the filler and create a mess.
Are you flexible of the coating you use and the method you finish the bases?
5/18/16       #3: Finsihing Oak ...
Joe Member
Sure I can try the paste filler, and see what happens I guess.
Joe
5/18/16       #4: Finsihing Oak ...
Oaks deep pores and grain make for a bumpy finish. When I spray Oak I thin my material considerably. Keeps it from building around the grain and lets it flatten out.
