Subject: Re: hickory table tops
hickory table tops
7/24/16
zedhead2156 Member
recently took a job where hickory with heavy character was requested, Table tops and bar top were fabricated out of this hickory. Two coats of catylyzed leveling sealer were applied with two coats of Magnamax topcoat. Now i am told that because of health department requirements....i need to fill in all knots and crevices.....preferably clear.....any input would be appreciated.
7/24/16       #2: hickory table tops ...
nick
I fill the knots prior to finishing 2 different ways;
the method I've been doing for years is epoxy with a little graphite powder added to make a translucent black. I over fill then sand back to flat.
another method I was just shown by a wood turner that works great for open grained woods as it simulates the open grain is to add coffee grounds to super glue, over fill then sand back to flat. you can really camouflage your knots with this method by using different colored and size grinds. I don't know but doubt if this method would work for large voids.
7/25/16       #3: hickory table tops ...
RobertJ
Another issue would be the use of Magnamax for a bar finish. Magnamax is a pre-cat lacquer. Why didn't you use Krystal?
7/26/16       #4: hickory table tops ...
Clear casting resin is about the only "clear". Epoxy has an amber cast. No idea how compatible it will be. I agree, precat is not a finish for commercial use!
7/27/16       #5: hickory table tops ...
Pete Anderson
Website: http://petesloors.wordpress.com
I use epoxy mixed with wood flour to thicken it. It comes out a little darker than the heart wood. I coat with conversion varnish.
7/27/16       #6: hickory table tops ...
mainzy Member
I use level sealer a post cat product from mlcambel.you can build 15 mill before standing. Awesome for filling any open grain and knots. I'm nit sure if you would be able to put it on top of manamax.give me a shout if you want more info . 1 207 272 6590
7/28/16       #7: hickory table tops ...
Zedhead2156
Sorry, i was mistaken......i used two coats of acid catalyzed level sealer with two coats krystal satin topcoat......problem is sealer in deep areas turned slightly milky
7/29/16       #8: hickory table tops ...
Pete Anderson
You will need to sand off the extra epoxy filler before you start finishing to get all the crevasses.
