Subject: Re: debris in white cv
debris in white cv
9/14/16
antonio
other than the obvious reasons like dirt in the gun or dirt in the air - what else could cause your finish to look like someone sprinkled sand on it while it was wet? Every now and then this happens, all guns clean as a whistle, spray booth clean, but like 3 out of every 4 doors sprayed look like small grains of sand all over it.
9/14/16       #2: debris in white cv ...
Shane
Trust me and run all your topcoat through a fine mesh cone strainer... you wouldn't believe what junk come right out of the can and it does find a way through your inline filters trust me..... I deal with this issue a lot and it's just part of our procedure in our booths running conversion varnish... we operate 8 open face booths 6 days a week and spray coating all day long.... We hand strain every ounce that's going to be a final coat...
9/14/16       #3: debris in white cv ...
Robert Member
Try zip tying a piece of Nylon stockings around the intake tube. Fold it over a few times and then zip tie it. You'd be surprised at just how much debris it will filter out so it doesn't become part of the coating.
Although not related to filtering, it helps to spray down the floor with water. 2 gallon garden sprayers work quite well and the pressure wont kick up any dust/dried over spray etc....
9/14/16       #4: debris in white cv ...
Bill Richardson  Member
Website: http://www.awwtx.com
+1 on what Shane posted, you'll be surprised at what is in the bucket, especially if it has been sitting on the shelf for a while. I go even further and strain any additive such as thinner, reducer, or retarder. I've seen trash in the filter more than once from thinner.
9/14/16       #5: debris in white cv ...
antonio
thanks guys! we pretty much strain everything with a fine mesh filter as it goes in the gravity feed gun cup. the only thing we do that kind of helps to minimize this problem is instead of doing one pass we do another pass which may be kind of pushing the ml thickness allowed for cv , but by doing this it seems to help drown the sand grains and makes them less noticeable.
9/15/16       #6: debris in white cv ...
Gerry
Are you sure it's not micro bubbles? If you get a good magnifying glass and look at the finish you will be able to tell.
9/19/16       #7: debris in white cv ...
Michael Foscone
You islanders be smoking to much weed to be asking a silly question, it probably is sand!
9/19/16       #8: debris in white cv ...
antonio
funny enough one guy did light up a whole sheet of laminate that had contact cement on it when he didnt realize and put his joint on top of it! (actually i think it was a cigar , but who knows over here they put weed in their cigars!
