Subject: Re: Matching needle to nozzle
10/8/16
Kevin
I seem to have acquired a number of needle and nozzle sets for a few Asturo guns I have. Problem is, the nozzles are marked but the needles are not. Anyone know how to match the sets? The smallest and the largest ones I can get, but some sizes are too close to call. I thought about a digital caliper, but not sure where to measure.
10/9/16       #2: Matching needle to nozzle ...
DanShaf Member
I would hunt each needle to make sure that there are no markings. All of mine are marked, etched.
10/10/16       #3: Matching needle to nozzle ...
DannyB
I believe you want to measure the smallest part of the front tip and order them by size.
My recollection for asturo guns is that you can tell pretty easily which are too small by which ones leave a gap in the nozzle or not.
You can tell which are too large by which tips don't fit all the way to the end of the nozzle.
(Note that if there is no gap, and it sticks out the right amount, you can use it, regardless of whether they are 'matched' or not. The only thing that it changes is how fast/slow the fluid rate changes when you adjust the knob, so ...)
10/11/16       #4: Matching needle to nozzle ...
Kevin
Thanks, good info. I have been just eye-balling the fit, sounds like that is as good as I can get. I was wondering how much of a difference it would really make, say switching a 1.4 needle for a 1.5. Sounds like maybe not much.
10/11/16       #5: Matching needle to nozzle ...
DannyB
Yup.
If it doesn't leak, it's a usable needle.
The larger needles just probably won't give you the fine tuning of flow rate that the right one would (i'm assuming the needle angle is slightly different between each one. If it's not, the flow rate tuning be exactly the same)
10/24/16       #6: Matching needle to nozzle ...
Eric
I use the eom touch up.. good gun but needles are marked.
Would never but another.
I use binks 2100, DeVillbiss Compacts, and Iwata Super Novas
Tried and true
