Subject: Re: Acetone
Acetone
10/24/16
Folz Custom Cabinets (Joe) Member
What is the difference between different brands of acetone if any? (Chemlife, Sherman Williams, MLC) Sherman Williams price is around half the price? Can I use it with Chemlife products?
10/24/16       #2: Acetone ...
Robert Member
I think that solvents can be equated to gasoline. Basically its all gas, but the difference is in the quality of the ingredients that's in each companies " package ".
10/24/16       #3: Acetone ...
herb johonson
typically you can get a lot of cost difference is the solvent is a blend of virgin and reclaimed acetone
that is what you have to check before you use it,
good luck
herb j
10/25/16       #4: Acetone ...
Leo G
When you are buying Acetone it should all be the same. Reclaimed may have some slight contamination of other products in it but shouldn't make a difference.
Thinners from different companies are specialized blends for their own products and may or may not be helpful out of system.
But just buying straight acetone you should be pretty safe buying the lower cost product.
