Subject: Re: RE: Hand-applied finish oil
12/9/16
Tommy
Which hand applied finish oil or something else can be done without a spray gun that brings out the colors and grains in the wood that can make it look almost 3D?
Wood is maple, spalted maple, and oak.
12/10/16       #2: RE: Hand-applied finish oil ...
Nick
For 20+ years I did all the finish work for a custom home builder who loved Daly's Pro-Fin. Doors, trim, cabinets, windows all got 5-6 coats (I did one job with 12 coats) combined with through sanding; starting with 220 for 1st coat, 320 for the 2nd, 400, for the 3rd, 000 steel wool (or equal) for the 4th, 0000 for all following coats with give you a finish with amazing clarity, depth (and if you did your sanding/rubbing until your tendons were about to snap) smoothness. But after all that you still have a finish of only fair durability that will require maintainance every couple of years in high use areas. The good news is; more 0000 rubbing and a couple of coats will bring the finish back to beautiful.
12/10/16       #3: RE: Hand-applied finish oil ...
RobertJ
Need more info. Furniture, cabinetry or ?????
