Subject: Re: Done with spray stain, option B
1/25/17
Ryan Groff
I think I've had enough with the spray stain,
its easy to use on flat surface or raised panel doors with moldings that ease into the panel, but hard for me on shaker style doors where the transition to the panel is sharp and square, if you go light you can't see the grain, if you go medium, you see the grain but you get pooling , stain build up on the edges thats hard to remedy, and still you risk panel shrinkage and ghost lines , and I'm sure my inexperience has a lot do with it, lol. So I'm going to try using a clear stain base, staining then toning, I need it simple as I can get, the simplest formula I've seen is
1) thin stain with clear stain base, how much, what is the ratio?
2)seal
3) toner to get where you need to be with color, then topcoat.
Couple of questions
1) ratio of stain to clear base thinned down?
2) do I just go over the board or door 1 or 2 times, or keep track when I tone it so the color is consistent, wouldn't it be difficult to keep the color right if you didn't do the exact same thing from piece to piece?
1/25/17       #2: Done with spray stain, option B ...
Ryan Groff
I also forgot to ask, Im using sherwinn williams sb stain, will it evaporate the clear stain base making it ineffective, since its a fast dry stain, I assume its solvent based.
1/25/17       #3: Done with spray stain, option B ...
Rick Mosher
We always pre-stained and sealed the panels before assembly whenever possible. That way if the panel shrunk in the winter there were no raw edges exposed and if they were a different color it eliminated masking.
A way around the problem if you're buying manufactured doors is to apply a base color of the spray on dye stain a little lighter than you need and then after a wash coat of sealer wipe on a glaze to get your final color and it will automatically color the inside edges that the spray on stain didn't get as well.
1/30/17       #4: Done with spray stain, option B ...
jonathan mahnken
nothing more simple than a wiping stain.
