Subject: Re: Problem with poly finish
2/1/17
Long Island timberworks
Website: http://www.litimberworks.com
Hello guys , I have a little problem which I could use some advice concerning a live edge redwood bar top that has a polyurethane finish on it.... I subbed out the finishing and the finish looked perfect ... It was done and installed about 8 mos ago... The top was dry to approx 8.5 mc... The finisher applied several coats of sealer followed by a couple coats poly... The customer sent me this picture saying the finish is peeling.... Before I contacted the finisher I wanted to hear from you guys as to what may have caused this and what may be the fix...
Oh and it's a very large bar top...30"x14'
View higher quality, full size image (750 X 1334)
2/1/17       #2: Problem with poly finish ...
Leo G
Doesn't quite look like it's peeling. Never heard of polyurethane needing a sealer unless you're talking about 2K poly.
2/1/17       #3: Problem with poly finish ...
Looks melted to me. Homeowner is trying to get a free fix for something done by one of their kids?
2/1/17       #4: Problem with poly finish ...
Yes I think I agree with you, it doesn't look as if it's peeling ... I was wondering the same , if the customer may have damaged it themselves ....
2/2/17       #5: Problem with poly finish ...
Shane
from looking at the pic it surely looks like heat damage... possible very the side edge of a hot pan or bowl melted the finish and then the top has been wiped down with cleaner/water several time... causing a bit of water damage where the finish has lifted...
2/2/17       #6: Problem with poly finish ...
Robert Member
Hmmmmm...bar ; looks like someone might have allowed a cigarette to damage the coating. Either the one who did it or the one who owns the bar tried to scrape off the bubbled coating. The raw wood under the scraped off finish, looks as if its a bit darker too. Customers issue, not builder or finisher.
2/2/17       #7: Problem with poly finish ...
That surface was damaged. End of story. Definitely not a defective coating. Its insulting that the customer is holding you responsible.
2/2/17       #8: Problem with poly finish ...
Guys thank you very much , I appreciate the feed back
2/3/17       #9: Problem with poly finish ...
ronb
It is very hard to determine the exact cause from the picture, but the small white lines radiating around the perimeter might be an indication the coating cracking as a result of an impact. The lighter color in the center would indicate that the coating released itself from the substrate. You would need to run your finger over the defect to be sure.
If this were indeed the case the lack of adhesion could be due to allowing too much time between sanding and sealing,or sanding with too fine of a grit. If a stain was involved improper dry time, an incompatible solvent in the stain, or even using the stain as a toner.
