Subject: Re: Curing waterborne finishes
3/17/17
Leslie Desnick Member
We are a manufacturer of picture frames and moulding and are considering a Prime Heat UV curing batch tunnel.
We currently use pre-cat primers and topcoat paints from Valspar and stains and clear coats from Chemart. We have also use some waterborne finishes from Valspar but eventually would like to spray water only. Anyone have experience or thoughts on PrimeHeat batch tunnels? Thanks.
3/20/17       #2: Curing waterborne finishes ...
Bob Niemeyer  Member
Prime Heat works very well. I have been at many production plants using Prime Heat Systems and they all work very well.
Now for the coating, not all waterbased coatings like the curing spectrum but if you get samples of the products you plan to use Prime Heat will run tests for you. If you run into any problems please feel free to reach out to me.
