Subject: Re: Waterborne finish on a wetbar wood top
5/17/17
Matt Calnen
Hi everyone. I have to make a Walnut countertop for a wet bar. I made a couple other tops For this home using Benjamin Moore stays clear and she is very happy with how they look and hold up. She likes a brushed look. My question is can you brush out a product like MLC Agualente? I thought maybe a fancier grade finish might be better for a cocktail area. I plan on epoxiing the top together and epoxing the undermount sink cut out opening. I usually spray the finish down and back brush it for the brush stroke effect. Her concern was repairabliaty as a top in her other house that I sprayed with CV I am unable to fix without removing it(and it's trapped with a fancy tile back splash). I guess my question is can I fix a damaged area by brushing it with a product like MLC agualente that is readily available to me? Thanks in advance
5/18/17       #2: Waterborne finish on a wetbar wood ...
MarkB Member
Ive sprayed a lot of agualente and I would never trust it on a bar top. I would be calling Jeff over at Target coatings and see what he has to say
5/20/17       #3: Waterborne finish on a wetbar wood ...
John Member
If I wanted a brushed look I would use a traditional varnish. Waterlox and Arm-R-Seal both look beautiful on walnut, both can be brushed on, and both are very durable against water, alcohol, etc.
John
5/22/17       #4: Waterborne finish on a wetbar wood ...
Pat
I do mostly waterbased finishing in my shop, but I've never been happy with how it looks on Walnut. An old school varnish like Behlen Tabletop Varnish or Epifanes marine varnish looks awesome and is easily repairable. For a larger bar, I roll it on with a foam roller and immediately brush it out. Takes 4-5 coats (with overnight dry time between coats) to get enough build, so it's not exactly production-friendly.
Cheers,
Pat
5/22/17       #5: Waterborne finish on a wetbar wood ...
I likewise would not expect Agualente to protect a countertop. Its a great product but not up to that job.
I used the predecessor to Aguatana called Aguabarnice on a qtr sawn white oak kitchen breakfast bar. That was in 2007. I saw it again in 2012 and it was still perfect.
I sprayed 8 coats(using it as grain filler) over 2 days and buffed it. Very nice product back then, so I would hope that the Aguatana is even better.
MLC 2K WB
5/22/17       #6: Waterborne finish on a wetbar wood ...
I had used tinted Sealcoat to pop the grain and brown it up. The ML 2K is water clear.
