Subject: Re: Add more finish to expired pot life finish?
12/19/17
Jeffer Member
I read a somewhere that small to perhaps moderate amounts of leftover conversion varnish (that is past its pot life) can still be used by adding more freshly catalyzed product to it.
I was curious what the thoughts in this community are to this suggestion. Too risky?
12/19/17       #2: Add more finish to expired pot life ...
I wouldn't use more than 10% of the expired finish in the new stuff. I've done in on occasion, but I don't like to take the chance.
12/19/17       #3: Add more finish to expired pot life ...
I would not even consider it. The one time it fails would cost way more than any money saved. The customer should have already paid for that material in the pot.
12/19/17       #4: Add more finish to expired pot life ...
Paul Snyder  Member
Website: finishing.tips
The data sheet for SW used to describe the ratio for "decatalyzing" the left over CV by adding uncatalyzed finish to it. Not sure if they still offer that info, but that's the one place I know it was documented by a manufacturer - and it worked for other brands as well.
I'm attaching an old data sheet that has this info - look at the note about extending the life....
Sherwin_Williams_SherWood_WW_CV_TDS___Temperature_Highlighted.pdf
12/19/17       #5: Add more finish to expired pot life ...
Pete Anderson  Member
Website: petesfloors.wordpress.com
I use CV on wood floors. The first coat/s are catalyzed just before use. The final coat is ore-catalized. The manufacturer has told me that as long as the first coats can be used/ spread then there will not be a problem. The first coats will start to jell after a few days with the lid closed at room temperature. I store the mixed finish in a freezer to prevent hardening. It comes out of the freezer in a jelled state and thins when it gets warm. I spread with a brush and lambs wool pad. The results are the same as mixing "fresh" finish. After a couple of weeks in the freezer the finish still gets used. The only problem is the freezer needs to be only for storing finish. The finish comes in quart cans, so a micro fridge works great. I spray it too, warming the can up in a hot water bath. No problem with either gloss or satin. The final coat never needs any refrigeration, just close the lid.
    • Supergrit Abrasives
    • Apollo Sprayers Inc.
    • EX-FACTORY
