Subject: Re: MLC Aguatana
MLC Aguatana
4/12/18
nick Member
One of the woodworking shops I do finishing for is working on a run of 300 restaurant tables that the owner wants to go with a green as possible finish and still have a durable, long lasting, easy to clean finish. I steered them towards the 2k poly finish I use (MLC Polarion) but the 600+ grams of VOC per liter makes it a no go.
MLC touts this product as being very durable, 120 grams of VOC per liter and tough enough for tables.
For those of you who have used this product I would appreciate sharing your thoughts on it. Thank You.
4/12/18       #2: MLC Aguatana ...
John Member
How about ChemCraft Post-Cat WB-Clear 2K at 80 g/lt VOC?
John
ChemCraft Link
4/12/18       #3: MLC Aguatana ...
DannyB Member
Aguatana is a bit of the pain in the butt to use because it has a sweat time, has to be mixed really really really well, etc. It is
It is not iso-free.
The newer iso-free 2k chemistries are just as good as the iso ones in practice, and often have better wear resistance.
Unfortunately, it's hard to tell whether you are getting something good unless you stare at the SDS or get enough info about the formulation of the catalysts.
4/13/18       #4: MLC Aguatana ...
DanShaf Member
..." a green as possible finish and still have a durable, long lasting, easy to clean finish."
Sure. Who doesn't want their cake and it it, too?
Sometimes the choices are tough. Go with green or look for durability. Nothing gets more used, abused, and looks the worse for wear than a restaurant table.
2k polyurethane or polyester.
4/13/18       #5: MLC Aguatana ...
nick Member
Thank you for the replies, The chemcraft product looks interesting, specs read like it's a lot less fuss then the aguatana plus no isos. I'll look into getting some to see how it works,
The restaurant owner(actually chain of restaurants) is aware that compromises will/may be made but is interested knowing exactly what those compromises are and I was told to investigate options. I have never used these 2k WB polys before but if their performance can live up to the sales lit. they sound like what my customer is looking for.
4/13/18       #6: MLC Aguatana ...
DeanV Member
I tried Aguatana when it first came out. Maybe it is better now, but pot life was AWFUL. It would start gelling in about 20 minutes tops and not pass through a PPS cup system at that point.
4/14/18       #7: MLC Aguatana ...
DannyB Member
If you are going iso-free 2k urethane, Mohawk's new product iso free is (M610-5207), IMHO, the current way to go.
I haven't tried Sayerlack's product here.
I usually only rely on their stains, because I had mixed results with coatings, but the iso-free 2k urethane they sell is great.
It's easy to apply, and can be thinned with normal n-butyl acetate
It was developed by DOW, who has done serious R&D work over the past few years on iso-free polyurethanes.
4/14/18       #9: MLC Aguatana ...
nick Member
DannyB, That sounds like a product I'd use...but not likely for this job as the amount of VOC is what the customers are fixated on which isn't a bad thing as long as I can find a product that also meets their performance expectations and be workable for me.
I really appreciate the Aguatana info from you and Dean...fighting 55 gallons of fussy finish for a week and a half is a good thing to avoid!
4/15/18       #10: MLC Aguatana ...
DannyB Member
Ah yeah, i forgot mohawk's uses some high voc solvents, sorry.
I don't remember if saylerlack's is the same way.
(unfortunately, it's easier to find iso-using 2k that is low voc because of formulation, though it's much worse for humans)
General finishes also has a similar-to-aqualux 2k product that is low-voc.
