Subject: Re: Resistant wrinkling over Clawlock 2
2/11/19
Phillip Burruss Member
I have Wrinkling problems every now and then With Resistant over Clawlock 2.Real bad today.I have been using this product for 28 years. Still haven't figured out why it does this sometimes. I have tried many things,but haven't figured it out yet. Does someone have a good answer why and how to fix it? I have talked to rep. Tech support. I'm almost ready to change to something else.HELP I love the finish.it finishes great
2/12/19       #2: Resistant wrinkling over Clawlock 2 ...
Shane
post your finish schedule... steps/times/sanding specs. etc etcas well as exactly your mix ratios and any additives... time between steps...
2/12/19       #3: Resistant wrinkling over Clawlock 2 ...
Phillip Burruss
First Catalyzed the Clawlock 2 withC149 Care Catalyst at 12.8 oz per gallon. Stir for 10-15 Mins. Add M.L. Campbell Thinner 20% C160 36. Stir for 10-15 Mins Spray one coat, no where even getting close to the max film thickness. some of the cabinets dried two days some one day some six hours. Sanded with 320 grit Free cut sanding paper. Blow off and Tacked with a tack cloth. Catalyzed The White Resistant with 12.8 oz of Care Catalyst C1491 Stirred for 10-15 mins. Sprayed One coat . Let dry for two hours maybe three. Wrinkled during drying.
2/12/19       #4: Resistant wrinkling over Clawlock 2 ...
Tyler
Had same issues. No one had good answers. Finally switched to a different brand, I haven't had a single issue since. that was 4 years ago. ML's service and tech support was really disappointing. Made the switch to chemcraft, they have significantly better primers, and topcoats work great. Dry times are also pretty superior.
2/12/19       #5: Resistant wrinkling over Clawlock 2 ...
Matt
Worn out sanding media can cause this, but obviously I cannot say that this was your issue.
You know how sanding sponges and orbital pads can get blunted, but still feel "rough enough" that you feel justified in using them, so you just scrub a little harder, trying to get all the life out of them you can.
I've found that this often burnishes it flat rather than scuff it smooth. That will prevent good intercoat adhesion.
I do have to admit, I only had this problem spraying Campbell. Same product-- Clawlock and Resistant, or Clawlock and Stealth. Happened on both, intermittently. Very frustrating. Since then we switched to Becker, and then later Sherwin Williams, neither of their CV's have done this.
The ONLY time we see this is when we are given "pre-primed" moldings, because the primer that is used on them is little more than a garbage layer of talc and diluted dollar store white glue.
2/12/19       #6: Resistant wrinkling over Clawlock 2 ...
Shane
I've seen many many post about problems with MLC in general... the wrinkling is not a sanding issue.. it's a chemical issue. You finish schedule is spot on and I do not have any other conclusion other than chemically the CV is a bad batch. I was thinking maybe you had some timing issues with the topcoat being sprayed over uncured primer or you could possibly box coating your topcoat and the first pass flashes too quickly and your next wet pass can cause it to wrinkle...
2/12/19       #7: Resistant wrinkling over Clawlock 2 ...
Jared Emery
I've had 2 bad batches of Clawlock 2 in the last 2 years. It's a shame, because when it works it behaves really well.
2/12/19       #8: Resistant wrinkling over Clawlock 2 ...
Dan
Tyler, which chemcraft primer do you use. We to are switching away fromMLC.
2/13/19       #9: Resistant wrinkling over Clawlock 2 ...
Phillip Burruss
I love resistant. What is the best finish for paint out there now. that is as good as Resistant?
2/13/19       #10: Resistant wrinkling over Clawlock 2 ...
Shane
E63W50041 This primer was formerly Becker Matador that is now absorbed into the Sherwin Williams Family..... builds like a dream and sands like a dream.... can be box coated to desired thickness and sanded back to spec to fill MDF edges/profiles if needed.... then Topcoat with the standard pigmented Kemvar Conversion Varnish they offer..... I literally go well over a thousand+ gallons a year of this material and have never had issues other than human mistakes... mostly sheen issues with the color matches they perform at the product finishes facility.... The finish itself is perfection.... for the clears I use T67F7 Vinyl sealer catalyzed and then I use their Becker product V84F90037 Kemvar 9320S.... absolutely beautiful and lays down like a dream if mixed out like I do with butyl cellosolve and the appropriate reducers/catalyst. awesome stuff...Never had a chemical issue... period with Sherwin
2/13/19       #11: Resistant wrinkling over Clawlock 2 ...
Tyler
I'm usig the chemcraft Plastiprimer & the PLasticolor. For clearcoats I'm using danseal & Evar-80. I've gone 5 years without any adhesion or wrinkling issues.
I'll never look back at ML Campbell. Their products just arent up to snuff. I had constant issues with adhesion and wrinkling that I just dont suffer from after moving to a superior product. The only good products they sell are their woodsong II stains, and Krystal. Everything else was a dissapointment.
2/14/19       #12: Resistant wrinkling over Clawlock 2 ...
Shane
Not a salesman..... Just a Finisher with over 25 years fulltime hands on experience spraying coatings and currently responsible for over $40 million annually worth of finished architectural woodwork... finish failure is not an option on multimillion dollar commercial projects so my job is to make sure I know what the heck I'm doing with a coating. Period.
8/29/19       #13: Resistant wrinkling over Clawlock 2 ...
The Dude
Curious as to how this turned out? Also, what was your substrate sanded to, before the primer was applied.
8/29/19       #14: Resistant wrinkling over Clawlock 2 ...
Phil Burruss Member
I gave up. Now I use white vinyl primer under it and have no problems. But wish I had a fix. Sanded always with 150 grit
