Subject: Re: Kemvar Sheen
Kemvar Sheen
2/18/19
Mark Member
I switched over to using SW Kemvar medium rub CV and I did half a set of cabinet doors one day and the other half a different day. The sheen is noticeably different, one looks satin the other looks high gloss. I catalyze first and then thin with butyl acetate, I usually mix and spray a quart or two at a time. The customer's preference is the satin look. Can I sand the sheen down and respray?
What would cause the difference in sheen with product out of the same 5 gallon can? I usually shake the can before pulling some out, is it possible I didn't ? Or maybe did I not use as much thinner on the glossy ones?
2/18/19       #2: Kemvar Sheen ...
CraigM
If you didn't fully stir/shake your pail it will affect the sheen for sure as the flattening agent sinks to the bottom. I usually stir a few times a day to make sure it doesn't seperate. Different thinning ratios can also affect sheen, as well as if you don't measure your catalyst properly. No problem to re-shoot the glossy doors with fully stirred product provided you stay within your maximum mil build.
2/19/19       #3: Kemvar Sheen ...
Matt
100% of the time this has happened and I've investigated it, it's because it sat for too long without being stirred and it settled out.
2/19/19       #4: Kemvar Sheen ...
Shane
I would go out on a limb to say your bucket has not been consistently agitated well throughout it's life cycle.... If your pulling material out at different times and not thoroughly agitating each time the sheen will obviously fluctuate throughout the bucket.... the amount of flattening agent is calculated to keep the whole lot at a specific sheen.... If you deviate from your process you will have different results.... Adding different amount of thinner in each batch will also affect sheen great.... obviously diluting the finish with more or less thinning is reducing or adding the amount of flattening agent.... After agitatation make sure to swab the bottom of the bucket to make sure it's not hanging to the bottom...
2/20/19       #5: Kemvar Sheen ...
Matt
By the way, the fix for this is just what you said--- you can scuff and topcoat with a freshly mixed batch from a well-shaken can.
