Subject: Re: Painted joints cracking
3/16/19
keith farr
Occasionally we will have Laquer paint jobs that stile and rail joints will crack after a few months Some Face frame joints will also crack We use hard maple for all our doors I know this is wood moving ( maybe cabinets built in humid conditions and then drying out from HVAC) I have started glueing all face frames and making sure stile and rail joints have glue skirting out at assembly and that seems to help some. Is there anything else that can be done to help with this ? Its very irritating to have a builder or home owner pointing out that onsite painters seem never to have that problem( of course they are using oil or laytex and the finish quality is much rougher and cracks don't show up as bad)
3/16/19       #2: Painted joints cracking ...
Time.
Glue in the joints, enough to squeeze out just a bit. And then time. I do a quick leveling of the joint with 100 grit. the the time part comes in.
You need to wait 3 days for the water to come out of the joint. Then a bit of putty whether you think it needs it or not, jest do it.
Then after the time has passed sand it with 150 to make sure it's flat. Good coat of primer and let it dry fully so you get it to sand to a powder,heavy scuff sand. Best is another coat of primer and a light touch with the sandpaper. Then coat as usual.
3/18/19       #3: Painted joints cracking ...
TiteBond 1 glue then what Leo wrote.
3 days dry is a bit excessive. Depends on what you are doing and the humidity/temp.
3/18/19       #4: Painted joints cracking ...
If you want to have zero issues, three days is the number. Yes it is long. But you can work it into your process.
3/18/19       #5: Painted joints cracking ...
CraigM
You could try switching to 2k polyurethanes, they are not as brittle and have more elasticity than cv's and lacquers so it takes more movement to crack them.
3/18/19       #6: Painted joints cracking ...
Keith Farr
Thanks for the responses. I can wait the three days to dry no problem. Paint shop runs very far behind. We have always used tightbond 2 because it works in our RF flyers but I will try the tightbond 1 on the doors. Thanks again
3/18/19       #7: Painted joints cracking ...
Just make sure to glue all mating surfaces on the cope of the door rail, not just the tongue.
3/21/19       #8: Painted joints cracking ...
John Bishop  Member
A lot of time it’s the amount of time before you machine them. We wait at least overnight before machining glue joints. I also agree three days in humidity is the number to wait.
Best of luck
D. John Bishop
3/21/19       #9: Painted joints cracking ...
This has been discussed many times in the cabinetmaking forum. Do a knowledge base search. We have been using Titebond 1, pocket screwing ff together, then glueing the frame onto box. I honestly haven't seen one crack in years and years. Usually caused by somebody dropping the box. We do many white semigloss beaded ff inset door. Not forgiving.
