Subject: Re: chosing air assisted airless advice
5/5/19
ozan Member
Hello,
These are my applications:
ML Champel Solvent base lacquers, Post catalyzed and pre catalyzed pigmented colors.
Magnamax white pre cat
Clawlock W3709 white primer post catalyzed
Magnalac Primer W350
here some I can't figure out which should I purchase. professional advice appreciate for my application,
OB14-C5 – B14 Air Assisted Airless Outfit / Bobcat
24F151 – Graco Merkur ES 15:1 Air Assisted Airless Spray Package
Kremlin EOS 10-C18
5/5/19       #2: chosing air assisted airless advice ...
mike j
Kremlin
5/6/19       #3: chosing air assisted airless advice ...
Brewster201 Member
Kremlin
5/6/19       #4: chosing air assisted airless advice ...
mauricio poli Member
KREMLIN
5/6/19       #5: chosing air assisted airless advice ...
herb johnson
all good choices but no their is so much parity with all the major brands including atomization capability, kremlin back in the day was the only one in the game now that has changed, i would check out the binks aa and graco aa systems both very robust and spray very well, me i am getting tired of kremlin part prices and parts kit prices although i still have their units, and they spray well and hold up well as do the others now i my shop i am not exclusively kremlin as i once was many many years ago- al lot depends on your local distributor service level
the cat will be the cheapest price that is available on the internet not a bad system and ml campbell lists out spraying pressures and setting for all their products on the cat website
good luck herb j
5/6/19       #6: chosing air assisted airless advice ...
Brewster201 Member
The Kremlin is by far the easiest to work on and the fluid section has one simple seal to replace when required. The fluid section is all Stainless Steel construction
Air motor is really reliable and simple
With the Kremlin you also get the Xcite spray gun which in my opinion is the best
Take a look at the Kremlin15-25 if in the future you will be spraying WB
5/6/19       #7: chosing air assisted airless advice ...
mike j
I agree. The Kremlin 15 will spray all you could ever need to spray. I have used the Kremlin system for 24 years and I have used the 15 pump for the last 6 years. I have sprayed all products through this pump and gun system, from conversion varnish, 2k poly, waterbourne primer and Satin Impervo, to BM Advance and Farrow and Ball Waterbased paint. We operate 4 different pumps and guns for dedicated products. Little clean time. Little waste. Low maintenance and reliable.
