Subject: Re: Deos 3x5 electric sander
5/8/19
Mace Member
Hello,
Looking at the Mirka Deos 3x5 electric sander. I know you can get a thicker attachment (pad) for contours, profiles etc.
Does this sander do well on those surfaces?
Thank you.
5/10/19       #2: Deos 3x5 electric sander ...
It'll work, but if you are thinking it'll work on crowns and moldings, most likely that'll be a stretch unless it's a very mild profile.
I use my Deos mostly for finishing scuffing, white wood face frame edges and breaking edges on my face frames
5/10/19       #3: Deos 3x5 electric sander ...
Mace Member
Thanks Leo,
Yes, I do a lot of crown molding type of sanding. I can contact a dealer and ask for a demonstration.
I can also check out SurfPrep sanders. They look like they may be more geared to that type of work.
5/10/19       #4: Deos 3x5 electric sander ...
If you had a shaped pad made it'd work great. I have a pad that's about 5mm thick and I use it when I'm sanding primers and top coats. When I white wood sand I use the original velcro hole. It's a great sander.
5/11/19       #5: Deos 3x5 electric sander ...
Mace Member
Thank you Leo!
