Subject: Re: Convert SATAminijet from gravity to pressure feed?
5/14/19
richard newman Member
I'd like to convert a SATA minijet from gravity to pressure feed so I can use it at any angle. Wondering if there is any reason this would not work?
I have a PPS adapter that I can re-machine to take a piece of tubing. I used to use an old Accuspray turbo unit with a remote pressure pot and found it way more convenient and comfortable, other than cleanup.
5/20/19       #3: Convert SATAminijet from gravity to ...
herb johnson
a little confused the advantage with a pps is that you can spray at any angle without losing a prime or leaking out a vent like a traditional gravity cup?
good luck
herb j
