Subject: Re: spraying 2k poly
spraying 2k poly
5/27/19
Ben Member
Need to spray ML campbells Polarian for the first time. Anyone have suggestions on tip sizes air setting for a CAT bobcat gun and pump set up?
How many coats of sealer / topcoat?
5/29/19       #3: spraying 2k poly ...
mauricio poli Member
You could start with 13 tip and check what you get. And then change to another one, depends on your quality and pore kind,
5/30/19       #4: spraying 2k poly ...
Nick
I agree with with the previous post, start with a ,013. If your looking for a finer finish you could thin it down and use a .011. I've been thinning it with butyl acetate. I'm usually spraying small jobs with it so l use a gravity gun with a 1.4 nozzle thinning 10% and that works good.
the stuff sprays easy and comes out beautiful. Give it at least a full hour to dry (1.5 hours would be better) before sanding this holds true for both the fast dry (1 hour pot life) and the 4 hour. I've been going wet on wet for my 2 finish coats and that has been working great.
Clean up right after use if you're hot potting and clean throughly as it's not easy to get dried finish off your tools.
5/30/19       #5: spraying 2k poly ...
Nick
PS; in my previous post if l wasn't clear l'm writing about using MLC Polarion as that is the only 2k poly l've used.
7/21/19       #6: spraying 2k poly ...
Denny J
I used a .411 tip with my bobcat gun. Thinning it .1 helps it lay out
