Subject: Re: undercatalyzed conversion varnish
6/2/19
nick Member
Greetings all-
About 2 years ago I built a large conference table (1 1/2" baltic birch exposed edge plywood, cypress veneer with solid wood inlay details). Apparently it didn't get used much until recently, but now there are major finish issues. My used-to-be-trustworthy finisher apparently undercatalyzed the conversion varnish finish, as it seems to have never fully cured/hardened. If you write on a piece of paper on the table, then lift the paper, you can see the faint outline of the writing in/on the finish. It gets dirty easily and seems to have a slightly gummy feel to it (looked great when it was originally delivered).
One finisher suggested a light sanding followed by water-based poly on top (this doesn't sound right to me but he says he's seen it work). Another finisher told me a slightly overcatalyzed CV on top after light sanding could work but is risky. I've read a normally catalyzed CV on top might fix it as well.
Obviously I'd prefer the easiest/fastest/cheapest fix, but it needs to be done right so I know that might mean stripping it completely (buries face in hands). If this is the ultimate decision- what is the best way to strip CV? The table is comprised of 4 sections which, together, are 5'x16', legs are removable steel. Thanks for any and all advice.
Also if anyone knows/recommends any good finishers in south Florida who might be willing to take on this nightmare, please let me know, thanks! Nick
6/3/19       #2: undercatalyzed conversion varnish ...
DannyB Member
Stripping is your only real option.
The catalyst needs to be able to force crosslinking *everywhere*, not just a thin layer on the top/etc.
It's basically impossible to turn it back into a completely liquid form and have the catalyst mixed and agitated into the result in the right ratio.
Even if you could somehow guess the ratio right enough to not cause white spots due to overcatalyzation, the thinner is highly unlikely to melt it all the way through and thoroughly mix it.
If you had screwed up one thin, small, coat, you might be able to get away with something here because you may be able to melt the entire film.
But a conference table would normally have whatever the max allowed is :)
So unless you have a magic way of guaranteeing your thinner is going to melt *all* of it, *all* the way down, and then a way of ensuring the catalyst makes it thoroughly into the result, all the way to the bottom as well, you are screwed here.
Wish i had better news.
Usual approach is to go get xylene and strip it all.
6/3/19       #3: undercatalyzed conversion varnish ...
rescraft
I'm assuming your "used to be finisher" will not take any responsibility for his mistake? Did you have a contract w/him?
Can he at least help pay for the materials needed for the fix?
6/3/19       #4: undercatalyzed conversion varnish ...
Nick Member
Thanks-
It’s complicated- the finisher who did it is out of business and on death’s door with a myriad of really bad health issues- maybe he never used adequate safety measures because he is really falling apart. I suspect he messed it up in the first place because he was all screwy on medications at the time. Suffice it to say he’s out of the picture unfortunately. Straight xlene with scrapers and rags? Have you ever used that MAGIC 555 stuff?
Plan B might be to slap the whole thing with laminate (buries face in hands). I’m hopeful the customer will have mercy on me and share the cost. Anything peculiar about contact cement sticking to conversion varnish?
THANKS!
6/3/19       #5: undercatalyzed conversion varnish ...
DannyB Member
Staring at a bunch of SDS for Magic 555, i don't think most will work.
Depending on how fast you want to do it, xylene or acetone will be your fastest way.
If it was not catalyzed properly, acetone should go right through it and be cheap in bulk.
It's also VOC exempt.
But you'd need to be careful as acetone will go through almost anything you've got protective clothing wise.
If you want something "less dangerous", something NMP based will probably work, and do a more thorough job, but it will take a while to work.
Citristrip is NMP based (right now) as an example.
There are other variants you could use.
I honestly would try to just pay someone to dunk tank strip it or something (depending how big a conference table we are talking)
6/4/19       #6: undercatalyzed conversion varnish ...
Shane
I'd build from scratch before I went down that path... IMO
6/4/19       #7: undercatalyzed conversion varnish ...
dan shaf Member
For stripper, get a couple of gallons of Dad's. It's got a decent amount of methylene chloride in it, so it's potent. It has no ammonia in it and no lye, so it won't darken any of the woods.
Score the existing finish with 100 grit, just to create a scratch pattern in the finish. This allows the MC to work its way into the finish film to break it apart and to cause it to want to unbond (mechanically) from the substrate.
Use a boatload of woodshavings to clean off the sludge instead of rags, instead of steelwool, instead of Scotchbrites.
Wear thick neoprene gloves. If stripper gets on your skin, it will sting. Remove the stripper from your skin with a rag soaked in water. A solvent-soaked rag drives the stripper into the skin.
Before stripping, yes, do try the over-catalyzed conversion varnish. Lightly scuff your existing finish, first.
The extra-hot CV will often -- not always -- kick the undercatalyzed finish underneath. Been there, done that, with proper success.
6/5/19       #8: undercatalyzed conversion varnish ...
The over catalyzed conversion varnish will either wrinkle the existing coating or it will fail prematurely because it's over catalyzed.
Either put a correctly catalyzed conversion coating on it (after light scuff) or put a vinyl sealer coat on it, catalyzed (ask your rep for percentage. I know 1% is good for MLC vinyl sealer). And then apply the properly catalyzed conversion varnish coating on top of that after a light scuff.
6/5/19       #9: undercatalyzed conversion varnish ...
Shane
I realize a lot of us have dealt with this issue at one time or another. Sure some of us may have shot another coat on it and called it good... the customer was probably pleased.... but the chemistry isn't going to lie... Sure the coating you put on top happens to lay out and cure on the surface...…. what's underneath is still a problem.... we all know a hard finish on top of a layer of soft finish is going to be the weakest link... it will fracture.... just when will it start? If you can sleep at night knowing it's wrong that's your deal..... Strip it and start over or remanufacture the product...
6/5/19       #10: undercatalyzed conversion varnish ...
Two thoughts, cypress is really soft and are you sure the writing isn't showing in the wood. Second, was some odd kind of cleaning chemical used by a new cleaning crew lately? Hard to imagine that in 2 years no one complained about sticky feel. It should have felt sticky when it left the shop if it was under catalyzed. Don't waste the time and money to apply something on top. Strip it down, do it right.
6/8/19       #11: undercatalyzed conversion varnish ...
nick Member
Thanks all- I really appreciate the responses! I too thought about the softness of cypress, but the same effect occurs in the hard edge grain of the baltic birch ply. The possibility of a cleaning crew's wax cleaning product would be a welcome discovery (to put it mildly); I plan to do another site visit to investigate more thoroughly. It's hard to describe the feel- it's not sticky, but kind of waxy. Fingers crossed someone just put a dumb cleaning product on it that can be easily removed.
The finish seemed fine when I first delivered it; good sheen, not sticky. I had to stack the leaves to transport (blankets between of course) and had them upside down on the floor on blankets to screw on the legs. When I originally left it was gorgeous.
It's also likely the space has been un-conditioned on and off and possibly getting very hot in the Miami heat- I don't think that would affect a proper CV finish, but maybe?
6/9/19       #12: undercatalyzed conversion varnish ...
JeffA
After reading your last post, another cause of the issue could be the varnish was over catalyzed. What you are feeling is the excess catalyst leaching out and laying on the surface. This doesn't always show up right away like you mentioned during the initial delivery and it also depends on how much it was over catalyzed. If this is the issue, it's an easy fix. Take 1 gallon of water and mix in a box of baking powder. Wipe the area with a damp cotton rag of the water/baking powder mixture. And dry off the area with another rag. You may need to do this a few times to get it all off. Don't reuse the damp rag, only use it once. And don't redip the dirty rag, always get a clean one.
