Subject: Re: PALISSANDRO PORE
PALISSANDRO PORE
6/4/19
mauricio poli Member
Hello Everybody
We are finishing some stairway pieces of this beautifull wood, somebody said it is from Africa, very expensive.
Here a photo from a piece, it is solid wood and very heavy.
The problem is it has very deep pores and we want closed pore PU finishing, because it will be used in a nice stairway.
We do not to use pigmented wood fillers, we want to use transparent filler to keep the wood´s beauty.
So we started using a polyester sealer with a syringe, in the next day we check and it seens the pore is very very deep, and we need to repeat several times.
Is there a faster way to close these pores with a transparent filler? That will not give us future problems?
Thanks again!
6/4/19       #2: PALISSANDRO PORE ...
Shane
there is a much better way..... you need to learn to spray polyester... It can be done in very small batches with a cheap siphon feed cup gun... the product kicks over very quickly so you will need to learn how to mix it properly.. as well as reduce it properly so that it flows and fills your pores... it's a bit of a fire hazard if you mix it in the wrong order... always keep a small paper cup with some of the mixed coating so you can check how fast it's curing. you can get your pieces set up to spray... mix your coating... spray your parts... flush your gun/equipment and repeat.... you can build polyester to completely fill the wood grain..... after fully cured you can sand all the parts back flat to reveal your fully filled pores and topcoat with 2K poly of your choice..
6/6/19       #3: PALISSANDRO PORE ...
Thanks Shane for you advice.
I was trying to avoid polyester, because we do not have good people to do it.
But we have to do this way, the costumer ask me more body, so there is no way out.
I had found a walnut wood putty, it has a beautiful color and will help us with the pores.
Thanks again
