Subject: Re: Pulling the trigger on a pump
7/14/19
mastercabman
Hello all
In a few weeks I'm going to go ahead and get a AAA pump
I'm going with CA tech.(Wurth group carries the line and MLC that I mainly use)
But I'm unsure on a couple things
1; bobcat or cougar spray gun?
What's the difference?
I spray WVP,magnamax,magnaclear,stealth, Krystal depending on jobs
2; pick up tube or hopper?
I'm not a full time finisher
Most of my finishing jobs are
Refinishing kitchens/vanities
Small custom add ons
Build and finish cabinets (but nothing in large scale)
Finish/install and touch up molding such as crown molding
So not like a cabinet shop that I will spray all day everyday
I'm leaning towards the hopper feed but I can't find out how big the hopper is
Any info and tips would be appropriate
7/15/19       #3: Pulling the trigger on a pump ...
Jon Member
I have a bobcat gun. Small and lightweight. No regrets.
I have a siphon tube, and a lot of times I am catalyzing 2-3 qts at a time in a gallon can, which I place inside an empty 5 gallon bucket.
I have thought about a hopper, but am concerned about the build up of finish over time.
The siphon tube will do a good job of emptying gallon can if you tip it inside the bucket and clamp the pick up tube so it stays at the very bottom.
I've never used a hopper, so maybe others will chime in with their experiences.
7/15/19       #4: Pulling the trigger on a pump ...
Bruce Tait Member
Website: http://www.taitwoodworks.com
I have the Bobcat gun and prefer it over the Cougar for the same reasons Jon mentioned. I have two pumps, one with a pickup tube and one with a hopper. Unless I’m doing a very large job and spraying continuously, I much prefer the hopper and it’s the pump that gets used most often. We spray all waterbornes so cleanup is not an issue. We are thinking about converting the pump with the pickup tube to a hopper setup.
7/15/19       #5: Pulling the trigger on a pump ...
mastercabman
So how much material can you put in the hopper?
7/15/19       #6: Pulling the trigger on a pump ...
Brewster201 Member
I suggest you look at the Kremlin Xcite gun
I consider this the best spray gun and easiest to clean and rebuild.
7/15/19       #7: Pulling the trigger on a pump ...
Brewster201 Member
I had the CA tech hopper. It was by far the worst hopper. It had a small 1/4" suction line and maybe a 1/2 gal size. It was of low quality but cheap $ lol
Bruce
7/15/19       #8: Pulling the trigger on a pump ...
Bruce Tait Member
We use a cart mounted hopper as we do a lot of onsite finishing. While I'm not sure what its actual capacity is, it's more than 1/2 gallon and the siphon tube is 3/8". We have the H20 AAA version pump. The standard version or wall mount pump may be different. I would call CA Technologies to get more detailed info you may need.
7/16/19       #9: Pulling the trigger on a pump ...
Kevin Dunphy
Website: http://www.kdunphy.com/
I was in the same boat I don't know about the bobcat .I pickup the AA I had the reps of Campbell and AA come by the shop lots of support.
Only picked it up because of using CV on boats .But all Campbell products spray like a dream even vertical
Tried different clear coats throught the gun not as good as Campbells
Switching over to 2k for boats
For restidental using only water based
The fumes and over spray were the most dramatic worth every penny
7/18/19       #10: Pulling the trigger on a pump ...
mastercabman
Thanks for the info
I looked up a website that carries those pumps
It does says that the hopper is 1 gallon
I think that would be plenty for the work that I do
7/27/19       #11: Pulling the trigger on a pump ...
mastercabman
Well,I did it!
Got a C14 peak wall mounted pump
I went with the cougar gun
I was told that the bobcat is a little smaller and might not be comfortable if you have big hands
It came with a pick up tube and ordered the hopper
I already built a cart for it but have not used it yet
Once I receive my hopper I'll test it out
