Subject: Re: Sticky wood finish
Sticky wood finish
8/17/19
Ken Member
The tables in the break room where I work have a 1 1/2" wood border. I don't know old the tables are or how they were finished, but the wood has become sticky. What is the way to fix this? Hopefully something easier than sanding and refinishing, there are about 50 linear feet with this problem. Thanks for helping.
8/17/19       #2: Sticky wood finish ...
Ken Member
BTW whatever I do needs to be food safe.
8/17/19       #3: Sticky wood finish ...
mastercabman
Could it be just dirt?
I would try to clean it first
Try some naphta,cleans grease,wax,and it safe to use
I would test on a small area first as always
If you need to refinish I would use polyurethane
BTW most finish is food safe when dry
8/20/19       #4: Sticky wood finish ...
Shane
most likely it's old nitrocellulose lacquer than has deteriorated from oils,cleaners and greasy fingers. cheap cabinet grade finishes were used by the manufacturer and what you see is finish failure.... I bet the finish can be scratched off with your fingernails since it's gummy, sticky and soft.... needs to be solvent stripped... sanded and refinished with a catalyzed material.... Probably more trouble than it's worth... IMO
8/26/19       #5: Sticky wood finish ...
Matt Meadows
Agreed with the above.
Personally I'd clean them off like they said, using a solvent. Naptha is great at this but DO NOT use naptha indoors in an office area unless you want everyone going home early. Even small amounts of that stuff can fume up an office. Trust me, I tried cleaning the "elbow schmoo" off our break room tables (the white plastic ones with the orange peel texture that everyone hates cleaning). It worked, but damn did it stink for hours in there.
If you really just want to freshen up the finish, clean them off and wipe on a couple coats of Watco Danish oil (one coat every 24 hours for 2-4 days). It's not the most durable thing in the world but it is a simple wipe-on oil/varnish blend that will look better than old zombie skin lacquer.
In my experience it's also a bit easier to clean, and recoating is way simpler. Just do not expect it to build a film layer or stand up to being cleaned with harsh stuff like bleach.
